Blackspear2
Apr 18, 2017Aspirant
R8000 causes slow internet
If I plug directly into the NBN provided modem (Arris CM8200B) with a network cable to use a Hybrid Fibre Co-Axial (HFC) technology connection, I am able to receive 28.73Mbps. If I then disconnect a...
- Apr 19, 2017
Thanks Aspirant, the issue is with wired, not wireless, and the solution seems to have been to disable QoS. We are now up to a Line Speed of 42.56Mbps and Download Speed of 5.32Mbps on a 100/40 connection. I understand it should be up towards 80Mbps, however this can be due to cable connections that are over 20yrs old. At least I have had a vast improvement by disabling QoS.
Cheers :D
Blackspear2
I have found that by turning OFF "Enable Dynamic QoS" I can get a speed boost to Download Speed: 13.99 Mbps and Upload Speed: 5.24 Mbps. There must be other settings that can be disabled to have more throughput.
Cheers :D
