Blackspear2's avatar
Blackspear2
R8000 causes slow internet
If I plug directly into the NBN provided modem (Arris CM8200B) with a network cable to use a Hybrid Fibre Co-Axial (HFC) technology connection, I am able to receive 28.73Mbps.  If I then disconnect a...
  • Blackspear2's avatar
    Apr 19, 2017
    Thanks Aspirant, the issue is with wired, not wireless, and the solution seems to have been to disable QoS.  We are now up to a Line Speed of 42.56Mbps and Download Speed of 5.32Mbps on a 100/40 connection.  I understand it should be up towards 80Mbps, however this can be due to cable connections that are over 20yrs old.  At least I have had a vast improvement by disabling QoS.
    Cheers  :D
