Iainthompson202
Dec 03, 2020Aspirant
R8000 connected to internet but not broadcasting a wifi signal....
Hi, I turned the router off to restart but when it came back on there was no network. I've tried a hard reset and also logged in to admin. While there I can see a yellow warning triangle on the wifi...
Iainthompson202
Dec 04, 2020Aspirant
Hi, thank you so much for replying..
Wired devices work
WiFi off button was not pressed although I tried to toggle it to see if that might fix it, it didn't
It's connected to a Virgin Media Super Hub 3.0
Running the latest firmware from Netgear
Dec 04, 2020Guru - Experienced User
Iainthompson202 wrote:Hi, thank you so much for replying..
Wired devices work
It's connected to a Virgin Media Super Hub 3.0---Which has its own integrated router function. This can cause a double nat. not saying its the issue but is a potential.
Running the latest firmware from Netgear--which is?
