AndySmith
Nov 12, 2023Follower
R8000 Connection Issues
I upgraded the firmware for the router on 8/4/2023 to V1.0.4.46_10.1.84. I began having problems initiating a connection in Outlook 2016 and TeamViewer. After troubleshooting both applications, I ...
Nov 12, 2023Guru - Experienced User
You're about 8 versions of firmware behind if you have the R8000.
Might try upgrading to the newest . Nighthawk X6 R8000 | AC3200 Tri Band Router | NETGEAR Support
