josh1e
Jan 18, 2017Aspirant
R8000 created blocked service, then removed but still active and confirmed in logs.
Hi. Using the menu item Advanced - blocked service. I created a custom blocked service (example block 1-65535 IP 192.168.0.241). This worked succesfully and blocked all traffic to that IP. ...
- Jan 22, 2017
Hi josh1e,
You should try the reset.
Check as well the new firmware.
http://kb.netgear.com/000036746/R8000-Firmware-Version-1-0-3-32
josh1e
Jan 19, 2017Aspirant
Firmware Version
V1.0.3.26_1.1.18
- JamesGLJan 22, 2017NETGEAR Employee Retired
Hi josh1e,
- JamesGLJan 25, 2017NETGEAR Employee Retired
Hi josh1e,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
