josh1e
Jan 18, 2017Aspirant
R8000 created blocked service, then removed but still active and confirmed in logs.
Hi. Using the menu item Advanced - blocked service. I created a custom blocked service (example block 1-65535 IP 192.168.0.241). This worked succesfully and blocked all traffic to that IP. ...
- Jan 22, 2017
Hi josh1e,
You should try the reset.
Check as well the new firmware.
http://kb.netgear.com/000036746/R8000-Firmware-Version-1-0-3-32
josh1e
Jan 19, 2017Aspirant
Firmware Version
V1.0.3.26_1.1.18
JamesGL
Jan 22, 2017NETGEAR Employee Retired
Hi josh1e,
