rv2010
Jul 14, 2016Aspirant
R8000 Current Date/Time is incorrect
The date/time on my router is wrong and shows up as 03 Jan 2015. I have set the timezone correctly (GMT +5:30) and currently running firmware version V1.0.3.4_1.1.2. I have read and tried most of the...
- Oct 25, 2016
Hi,
I finally found what was happening. My son plays the Game Overwatch from Blizzard, When the game tried to do an update, for some reason, the router would reboot every time and reset the date/time.
I researched the topic and found that other people had the very same issue. The resolution was to change the "NAT Filtering" from "Secured" to "Open".
The router has not rebooted since and Overwatch updated 4 times so far.Thanks.
JamesGL
Oct 24, 2016NETGEAR Employee Retired
Hi mboire,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
mboire
Oct 25, 2016Tutor
Hi,
Thanks.
- JamesGLOct 27, 2016NETGEAR Employee Retired
Hi mboire,
Observe the connection. If it is working already please tag your post as accepted solution to close this thread.
JamesGL
Community Team
- JamesGLOct 30, 2016NETGEAR Employee Retired
Hi mboire,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
