mmmix
Apr 08, 2017Guide
R8000 Date and Time incorrect
Firmware Version V1.0.3.36_1.1.25 Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions men...
- May 25, 2017
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
William10a
Apr 08, 2017Master
What modem and isp are you using ATT and the netgear router not setting the correct time and date have been posted before?
- mmmixApr 08, 2017Guide
It's Comcast with an Xfinity modem TG862G set in bridge mode
- William10aApr 08, 2017Master
It should be able to go out on the web and pull the time and date in for the router use.
It *should* but it doesn't, that's the issue... Plenty of people have reported it in these forums, and I know some "special" firmware has changed hands, but I'm on the latest (I think)...
