mmmix
Apr 08, 2017Guide
R8000 Date and Time incorrect
Firmware Version V1.0.3.36_1.1.25 Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions men...
- May 25, 2017
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
mmmix
Apr 08, 2017Guide
It's Comcast with an Xfinity modem TG862G set in bridge mode
William10a
Apr 08, 2017Master
It should be able to go out on the web and pull the time and date in for the router use.
- mmmixApr 08, 2017Guide
It *should* but it doesn't, that's the issue... Plenty of people have reported it in these forums, and I know some "special" firmware has changed hands, but I'm on the latest (I think)...
- XemuApr 08, 2017Tutor
Are you able to edit the IP address for the NTP server?
- mmmixApr 09, 2017Guide
I can't see anywhere in the settings to change the NTP server. The PCs on my network can see a range of NTP servers with no issue.
- William10aApr 08, 2017Master
I also saw something about a beta firmware can not remember which model router is was for and if it work even it was the r8000 and work only people on a list were able to receive it from netgear support channels for testing.
I know this is not much help
