mmmix
Apr 09, 2017Guide
R8000 Date and Time incorrect
Firmware Version V1.0.3.36_1.1.25 Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions men...
- May 26, 2017
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
rednevals
May 08, 2017Tutor
This is really unacceptable... All files I created on my readyshare drives have the wrong date.
Guess it's time for dd-wrt ...
JamesGL
May 10, 2017NETGEAR Employee Retired
Hi rednevals,
What is the time and date of your router?
What is the firmware version of the router?
- rednevalsMay 10, 2017Tutor
Current Time: Friday, 02 Jan 2015 09:58:33
Firmware Version: V1.0.3.36_1.1.25
Normally I would not care, but since I use Readyshare it matters. All the files use this data/time when created/updated.
- JamesGLMay 19, 2017NETGEAR Employee Retired
Hi rednevals,
Reflash the firmware and reset the router. Reconfigure it manually.
https://kb.netgear.com/000037342/R8000-Firmware-Version-1-0-3-36
- JamesGLMay 22, 2017NETGEAR Employee Retired
Hi rednevals,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- mmmixMay 23, 2017Guide
I certainly still need assistance. It is totally unacceptable that in 2017 a top brand router is unable to simply set its correct date and time. I desperately want to use the schedule feature to shut off internet at night, but I just can't.
What can you do to escalate this to someone who can fix it. Or if you can't, change the interface to at least allow it to be set manually.
- JamesGLMay 26, 2017NETGEAR Employee Retired
Hi mmmix,
- mmmixMay 27, 2017Guide
Yes, I can confirm that it has fixed the issue. My router now shows the correct time. Many thanks!
- JamesGLMay 29, 2017NETGEAR Employee Retired
Hi mmmix,
Glad to know it is working now. :)
- rednevalsJun 04, 2017Tutor
This does not solve the problem for me. I have my R8000 behind a WNDR3700v4 running as an AP. Readyshare is disabled on the WNDR3700v4 and active on the r8000. The attached drives are where my problem is. The R8000 cannot automatically update its time, so any files I create on the R8000 's Readyshare have the wrong data/time.
Is there a way to allow the R8000 to synchronize the date/time either from the WNDR3700v4, or passthrough to the internet?
Both routers are on the latest firmware.
R8000: Current Time: Wednesday, 07 Jan 2015 05:31:41WNDR3700v4: Current Time: Sunday, Jun 04, 2017 14:10:31 - William10aJun 04, 2017Master
If you are using both wifi you reverse the placement of the routers and make the r8000 the main router and the other the access point just a idea.
Yeah, that would work. It would be a pain though. It's just sad that Netgear has this issue.
I also can't use the ReadyShare on both routers at the same time either.
