mmmix
Apr 08, 2017Guide
R8000 Date and Time incorrect
Firmware Version V1.0.3.36_1.1.25 Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions men...
- May 25, 2017
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
JamesGL
May 18, 2017NETGEAR Employee Retired
Hi rednevals,
Reflash the firmware and reset the router. Reconfigure it manually.
https://kb.netgear.com/000037342/R8000-Firmware-Version-1-0-3-36
JamesGL
May 21, 2017NETGEAR Employee Retired
Hi rednevals,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- mmmixMay 23, 2017Guide
I certainly still need assistance. It is totally unacceptable that in 2017 a top brand router is unable to simply set its correct date and time. I desperately want to use the schedule feature to shut off internet at night, but I just can't.
What can you do to escalate this to someone who can fix it. Or if you can't, change the interface to at least allow it to be set manually.
