mmmix
Apr 08, 2017Guide
R8000 Date and Time incorrect
Firmware Version V1.0.3.36_1.1.25 Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions men...
- May 25, 2017
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
William10a
Jun 04, 2017Master
If you are using both wifi you reverse the placement of the routers and make the r8000 the main router and the other the access point just a idea.
rednevals
Jun 04, 2017Tutor
Yeah, that would work. It would be a pain though. It's just sad that Netgear has this issue.
I also can't use the ReadyShare on both routers at the same time either.
