mmmix
Apr 08, 2017Guide
R8000 Date and Time incorrect
Firmware Version V1.0.3.36_1.1.25 Just cannot get this router to set the correct date and time from the internet, which makes the scheduling function useless. Tried all the other suggestions men...
- May 25, 2017
Hi mmmix,
Have you tried this firmware?
https://kb.netgear.com/000038688/R8000-Firmware-Version-1-0-3-46
Reset it after the update.
Jun 04, 2017Guru - Experienced User
If you keep the WNDR as the main host router and want to use the R8000 behind it, be sure to use the DMZ on the WNDR for the IP address it gives the R8000. However I recommend swapping around routers like William mentioned.
rednevals
Jun 04, 2017Tutor
What will adding the r8000's IP address(192.168.1.2) as a DMZ on the WNDR(192.168.1.1) accomplish?
- FURRYe38Jun 04, 2017Guru - Experienced User
Allow all ports and traffic unhinder by the WNDR router, to the R8000 router. Sometimes I do then when testing two routers in line. Helps with double NAT issues in this configuration.
- rednevalsJun 04, 2017Tutor
It still does not allow the r8000 to get the time from NTS...
Also: WNDR(LAN),DHCP(on) -> R8000(LAN). DHCP(off).
Need to connect the R8000 with its WAN port to the WNDR routers LAN port when using this configuration with DMZ. Time features required the WAN port to be used.
