Gert8
Sep 15, 2019Aspirant
R8000 DLNA question
Hello, I have a question. In the latest FW of the R8000 Netgear stops supporting DLNA. Does that mean the DLNA server functionality's of the R8000 itself are no longer supported? I didn't install th...
- Oct 18, 2019
Well, i found the sollution thanx to Synology. I had to change a settings in the R8000. The setting Advanced > WAN Setup > Disable IGMP Proxying was selected (so the feature was disabled). I had to uncheck it so tha the feature IGMBP Proxying was enabled. Emmediately after that all my tv's found the NAS again and all dlna devices were registerd in the NAS. Thank yoy Synology!
antinode
Sep 15, 2019Guru
> IF i perform an FW upgrade (in which DLNA won't be supported anymore)
> do a have the risc that DLNA won't work in my network anymore?
No. What it means is that the R8000 itself will no longer act as a
DLNA server.
> [...] I use a Synology NAS as DLNA server, so i guess the R8000
> doesn't need to support this? [...]
Right.
Gert8
Oct 18, 2019Aspirant
- schumakuOct 18, 2019Guru - Experienced User
The IGMP Multicast on the [W]LAN should work, regardless of the IGMP proxy config for the WAN interface. But hey, welcome to Netgear ... so we never know.
