woodwheels
Sep 03, 2021Guide
R8000 DNS fails first two hits then works.
This just started in the past week. It first looked like a connectivty problem, but on deeper diagnosis it was DNS and took a few days of struggling to figure out. When you go to a new site, the rou...
Sep 03, 2021Guru - Experienced User
you're not the only one with this issue and not even just this model.
There's been quite a few different models hit with this same issue so I'd like to think netgear is aware of it.
woodwheels
Sep 14, 2021Guide
plemans you seem to be a super user here, is there going to be a fix for any of these issues or just the nice comment that there are other models that have the same problem? It's a nice thing to know, but doesn't really help fix the router? Can you convince Netgear that this is a problem that should be addressed? I would think connectivity issues would be a pretty high priority for a router company..?
- plemansSep 14, 2021Guru - Experienced User
Unfortunately superuser just means I help a lot of people on here.
We're still just people from the public helping out.
Not a whole lot more contact with the moderators much less the firmware teams.
