Retired_Member
Aug 25, 2021R8000 DNS_PROBE_FINISHED_NXDOMAIN
I started to get the DNS_PROBE_FINISHED_NXDOMAIN error along with ERR_NAME_NOT_RESOLVED since a recent update as well. It is distressing and has been causing me anxiety. I purchased the unit in Ma...
- Aug 26, 2021
1. this is the community support forum. Where members of the public helping out. Threatening things is likely to get you less help, not more. since we're just people helping out and not paid to do this. and we're not netgear.
2. if you'd read the forums, you should see that most are simply downgrading to the prior version and fixing the issue. I'd recommend trying that first.
Aug 26, 2021Guru - Experienced User
- drzwave2Oct 08, 2021Initiate
Downgrading is likely to result in security leaks.
We MUST DEMAND that Netgear simply release another quality release to fix this problem!
I have a lot of problem with getting my companies VPN working because it times out multiple times before the DNS finally goes thru.
- DMP11400Oct 09, 2021Tutor
I just received notice a few days ago about the firmware update and it completed seemingly w/o a problem. The version I upgraded to was V1.0.4.76_10.1.82. I have been having problems ever since. I see problems with an August update, but not with the newer one. Is this update a problem too?
