Retired_Member
Aug 25, 2021R8000 DNS_PROBE_FINISHED_NXDOMAIN
I started to get the DNS_PROBE_FINISHED_NXDOMAIN error along with ERR_NAME_NOT_RESOLVED since a recent update as well. It is distressing and has been causing me anxiety. I purchased the unit in Ma...
- Aug 26, 2021
1. this is the community support forum. Where members of the public helping out. Threatening things is likely to get you less help, not more. since we're just people helping out and not paid to do this. and we're not netgear.
2. if you'd read the forums, you should see that most are simply downgrading to the prior version and fixing the issue. I'd recommend trying that first.
kevinfitzirl
Sep 17, 2021Initiate
The only solution I have found to overcome this issue is downgrade the firmware to V1.0.4.68_10.1.75. I understand Netgear are aware of this issue and did issue new firmware today (Sept 17, 2021) but that did not resolve the issue (for me, anyway), but once I rolled back to V1.0.4.68_10.1.75 all was good again.
Hope that helps.
- Retired_MemberSep 17, 2021
Thank you!!!
