NathanV22
Sep 16, 2021Aspirant
R8000 DNS stops working
After rebooting the router it works for a while. Then drops connection going in and out.
Sep 16, 2021Guru - Experienced User
NathanV22
We’ve got a Netgear CM1200 modem running over 100mbps
- FURRYe38Sep 16, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
