rheeboy
May 14, 2020Guide
R8000 Dropping connection to devices.
I purchased a new Nighthawk R8000 (firmware V1.0.4.46) a month ago (April 2020) and I consistently have devices (iPhone, iPad, etc) that keep dropping their connections to the router. The internet ...
- May 16, 2020
I just installed the recommended firmware this morning. I'll report back in a few days when there's enough time to see if the problem has been resolved.
May 14, 2020Guru - Experienced User
Try installing version 1.0.4.28 of the firmware. Afterwards (once its fully rebooted), factory reset the router and manually install it. Don't install from a backup. Also, disable auto update.
Then see how it does.
rheeboy
May 14, 2020Guide
Thank you. How do you install firmware 1.0.4.28?
- plemansMay 14, 2020Guru - Experienced User
to download it go to the support site:
https://www.netgear.com/support/product/r8000.aspx
click downloads and then +view previous versions. Download the appropriate version and then extract it.
After that you can follow the manual firmware upgrade process from the manual. And instead of using the new firmware, use the version you downloaded.
- rheeboyMay 15, 2020Guide
Thank you. I'll give it a try over the weekend. Also, is it good to use the SMART CONNECT feature or should I connect each device individually?
- plemansMay 15, 2020Guru - Experienced User
Some people love smart connect for the single ssid function. Others prefer them seperate so they can assign which band devices connect to. its all personal preference.
MTWOODLAND please start your own thread. Your device isn't the same.
