templarpsi
Feb 12, 2021Aspirant
R8000 Dropping Connection, tried everything
Model: R8000
Firmware Version: V1.0.4.68_10.1.75
I bought the R8000 model back in November 2019, and it worked great until the last 2-3 months, but this past 2-3 days I've noticed it has gotten significantly worse. I've tried everthing from resetting the modem, to factory reset, to even having the ISP come out and look at my modem. My modem works fine and the cable lines are great. I tried doing a DNS flush, and nothing seems to work.
The lights on the router are white, they all do blink, but occasionally some of the lights that blink will be solid for a good amount of time maybe 1-5 seconds at a time, and that varies from the 2.4 to the 5ghz band light. When I'm browsing I'll get a DNS error a lot or when I enter a website, there would be a huge delay before it finds the wesbite or sometimes just get that DNS error.
The connection seems to be more unstable than usual, I'll have good connection for about 5-10 mins than itll drop in and out for a good few mins, and the cycle repeats. I'm not sure if my router at this point is going out, or how I can tell.
I'm not sure what to do or if I should just purchase something complete different.
Worse at what?
You haven't said much about what is going wrong on your router.
It loses the Internet connection?
The wifi dies?
The exact message? Browsing what? Which browser?
- templarpsiAspirant
Worse at what?
----- in terms of keeping a stable connection. I would be browsing, than all of a sudden It'll take forever to load any page including google.com or just basic websites in general (yahoo, google. cnn, fox, school websites, etc), sometimes at the bottom left of my browser it'll be stuck at "resolving host" or whenever I type something in the address bar and hit enter, whatever I typed in would disappear and have a large delay of what typed in and suddenly it'll load my page. The DNS issue occasionally happens, but not all the time. As I'm writing this it's even happening now. The connection seems just so unstable at times, I can be browsing and doing my normal school work and it works fine, than within a blink of an eye I start to experience all the issues mentioned above. What's really strange about any of the connection issues I just mentioned also is that my router lights are always blinking, even when the issues are happning, I just noticed the lights will stay solid for a good 4 seconds when the issues are happening and then blink, not sure if that helps but ya.
You haven't said much about what is going wrong on your router.----see first response above
It loses the Internet connection?----See first response above
As I said before I've tried contacting my ISP and they've came out twice and tested my lines and modem and said it was fine. They think its my router, and I'm starting to believe that as well. I've tried a DNS flush, clearing my browsing history and cookies. I use Chrome primarily but I notice this issue still persist on other browsers like microsoft edge, and firefox. I'm not super computer network saavy, but I can't seem to figure out what else I can do to fix the router or to can it and just get a new one. I've gotten to the point now where I have to reset my mode and router at least twice a day, and its annoying as F.
Unfortunately, I still do not have much of an idea about what happens at your end.
Your detailed explanation seems to add up to "it doesn't work".
It seems that you are using a wifi connection. But you don't say. Have you tried using a wired connection in the router to check if that also freezes?
It seems that the wifi LEDs are behaving as expected, but you don't say which one are blinking or going "solid".
So, let's start at the beginning.
What is the modem, if there is one, in front of this router?
