Reenio's avatar
Reenio
R8000 drops internet connection
My Netgear router is contantly dropping connection. It was working fine for the first 6 months after purchase. I had updated the firmware months ago and everything was working fine afterwards. Connec...
  • Reenio's avatar
    Reenio
    Jan 23, 2016
    Thank you. It turned out there was a line problem. Too much static. It was all cleared on the ISP end and now works to its expectations again.
