Rossco864's avatar
Rossco864
Follower
Oct 03, 2015
R8000 drops internet connection
I'm having trouble with my R8000 dropping the internet connection frequently. The power button turns amber everytime this happens and I have to power cycle the router twice to get it to reconnect. Ha...
  • JamesGL's avatar
    Oct 05, 2015
    Hi Rossco864,
    Welcome to Community!
    I just want to verify if the LED that turns amber is the power light and not the Internet light. If it is the powerlight, you might need to plug the router on a different power outlet or use a different power adapter with the same specification as the its adapter.
    JamesGL
    Community Team
