apil1's avatar
apil1
Apprentice
Dec 01, 2017
R8000 Firmware 1.0.4.4 Wireless Drops
I updated my R8000 router to firmware 1.0.4.4 this week, and have been getting 5GHz WiFi drop only on Android phones.  I do not use 2.4GHz unless the device is not dual-band to know if it is also an ...
  • apil1's avatar
    apil1
    Dec 03, 2017
    WiFi Analyzer doesn't pick up any other 5GHz networks in the area, so interference shouldn't be an issue.  Since I removed the bridge, the connection has been fine on 1.0.4.4.  Not sure when it went defunct, but the last router reboot must have disconnected the bridge for good and it kept trying to send connection requests.  Best guess is either Windows dealt with the issue gracefully, or Android phones being lower priority on the router kept getting the boot.
