Mili's avatar
Mili
Guide
Jul 10, 2020
R8000 firmware 1.0.4.52 update causing frequent disconnects
Hello, I recently updated my R8000 to firmware 1.0.4.52. Since then, my wifi signal is frequently down, i have difficulty connecting to my ssid, internet connection doesn`t work. The only way to res...
  • Tex-Hogger's avatar
    Tex-Hogger
    Jul 15, 2020
    From the netgear home page click on support, then put r8000 in the seach fied. Select first one that comes up in the list.  From the next page cick the downloads button, then the "+" to view previous versions, then click on the download button for 1.0.4.46.  Once you get that file downloaded, open it and inside the .zip file there is R8000-V1.4.0.46_10.1.63.chk file, copy it somewhere where you can find it, like on your desktop.  Then goto your routers login page, goto the advanced tab, Adminstration, Router Upgrade and browse for the file from above. Let it do it's thing.  It will take a few minutes.  Once your router reboots a few times, let it settle down for an hour or so and then it should be running that older version of firmware.
    I am by no means an expert on flashing, or updating the firmware, but every time I have done it I have not had any issues.  If I didn't have such a large DCHP table built on my router, I would be really looking into finding a version of DD-WRT to run on my router.  But things on that front have been not to stable, and my family is not happy with me messing with our network all the time.  They "just want it to work."
    Tex-Hogger
