MrZen
Mar 27, 2017Aspirant
R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks genie app, local and remote management
Upgrade to V1.0.3.36_1.1.25 has left me not being able to remotely or locally manage router using the genie app. I have also noticed the router being very sluggish with connectivity since the upgrade ...
- Mar 28, 2017Do I need the previous fw to roll that back? If so where can I get it? Thanks!
MrZen
Mar 28, 2017Aspirant
- MrZenMar 28, 2017Aspirant
I rolled it back to V1.0.3.32_1.1.21 bits and everything back to normal, this current relase should be pulled to fix the issues then released again.
- TheWorstPingApr 01, 2017Apprentice
where did you find this firmware? id like to roll mine back
