MrZen
Mar 27, 2017Aspirant
R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks genie app, local and remote management
Upgrade to V1.0.3.36_1.1.25 has left me not being able to remotely or locally manage router using the genie app. I have also noticed the router being very sluggish with connectivity since the upgrade ...
- Mar 28, 2017Do I need the previous fw to roll that back? If so where can I get it? Thanks!
MrZen
Apr 01, 2017Aspirant
http://downloadcenter.netgear.com just search R8000 and select the correct bits.
- ElaineMApr 03, 2017NETGEAR Employee Retired
Did it work after updating the firmware once again?
