Djjvb
Jan 10, 2022Aspirant
R8000 firmware update takes ages or has crashed? No amber blinking power.
I updated the firmware of my Netgear R8000 as always in the control panel. It started with updating and dowloading. But after a minute or so, it lost connection to the control panel. A reboot or...
- Jan 10, 2022
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.A factory reset maybe needed...
Jan 10, 2022Guru - Experienced User
- DjjvbJan 10, 2022Aspirant
I don't know the exact firmware version. I think it went from the 58 to the 76 version. But that is something I hopefully remembered correct. And I can't look it up right now.
I don't have an ISP modem in between the router. I have a fibre connection which is connected via a media converter to a managed swich, which separates the VLAN with the internet.
And haven't powered off. Since I was afraid I would corrupt the firmware update? But I will try then....
[Edit} It was the solution eventually. Thank you very much FURRYe38. I was hesitative to try, because of the firmware update.
- FURRYe38Jan 10, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
