rorton
Mar 23, 2020Aspirant
R8000 firmware upgrade
The latest R8000 firmware upgrade states that iTunes Server is not supported. How does that affect iTunes?
- Mar 23, 2020
No, it usually hosts on the pc/laptop its installed on. Unless you specifically set it up for a server to run on the router
Mar 23, 2020Guru - Experienced User
if your not using itunes server off the router, it doesn't.
If you are, then don't upgrade.
