Mgingrich
Oct 31, 2021Aspirant
R8000 firmware v1.0.4.76 causing issues
Wondering if anyone else is having issues with the latest firmware update on the R8000 router? The wifi signal keeps dropping (hardwired appears fine) and I’m having to reboot it every couple of days....
Oct 31, 2021Guru - Experienced User
Try downgrading back to what was working?
- MgingrichNov 08, 2021AspirantFactory reset seems to be solid for about a week now. Hopefully that did it. Thanks!
