rowets's avatar
rowets
Guide
Nov 05, 2018
R8000 Firmware v1.4.1.30_1.2.26 won't restore config from previous firmware
Hi guys   I've just upgraded to the latest version of the firmware for my R8000. There was lots of messing about (Netgear servers must have been busy or something) but after the firmware was appl...
  • rowets's avatar
    rowets
    Nov 13, 2018
    So my accepted solution (NG want me to provide one), is to no longer use NG for saving lots of config as they can trash my data whenever they want and expect me to type it in again - not doing that!
    Instead I'm using a Raspberry PI as a DHCP server and disabling this feature on the NG router.
    That way I can properly back up the settings.
