thwooldr
Aug 15, 2017Aspirant
R8000 Firmware will not update
Router firmware will not update. current version 1.0.3.32_1.1.21 new version downloaded R8000-V1.0.3.48_1.1.33.chk. I used a hardwire connection directly connected to router. Never updates, the admin...
- Aug 21, 2017
Hi thwooldr,
Are you using the Desktop Genie or the web UI to update the firmware?
JamesGL
Aug 21, 2017NETGEAR Employee Retired
Hi thwooldr,
- thwooldrAug 21, 2017AspirantI was using the GUI. It never would install the fw. So I reset to factory. Then it allowed me to install the fw. Then I restored from backup. All works well now. Thanks for the help
