Retired_Member
Nov 03, 2015R8000 FW 1.0.3.4
http://www.downloads.netgear.com/files/GDC/R8000/R8000-V1.0.3.4_1.1.2.zip
- Aug 10, 2016
It looks like Netgear have in fact abondoned the R8000, while they still seem to support the R7000! Disgusted, I guess the next move is Asus.
The IP6 issue is a joke!
JamesGL
Nov 17, 2015NETGEAR Employee Retired
Hi Falcon,
Please check the post below for our responses in your inquiry.
JamesGL
Community Team
big_j_ny
Nov 18, 2015Aspirant
How come this FW is not coming up from the FW updating option in the R8000's UI (192.168.1.1)?
- JamesGLNov 19, 2015NETGEAR Employee Retired
Hi big_j_ny,
There might be a problem with the genie connecting to the server but you may download it in support site.
http://kb.netgear.com/app/answers/detail/a_id/30010
JamesGL
Community Team- JvaillancourtNov 19, 2015Aspirant
So I upgraded FM and reset factory settings and I still cannot get cloudshare to work. Im very disappointed beause I called tech support and they tried to sell my some 1 year long remote feature and would not help me get this working. The best i could tech tech suppoprt to do was point me to a generic instruction that ive done a hundred times already. Im having the same problem where if I hit refresh in the Readyshare tab i can see ready cloud for a splt second but then it dissappears. New update FM did not fix this. Ive spent about 5 hours total trying to get the cloudshare to work with no luck.
- ElaineMNov 20, 2015NETGEAR Employee Retired
Jvaillancourt Are you getting any error message? Or it just basically disappear?
I suggest that you re-flash the firmware of the router. Re-flashing means uploading the same firmware version.
Make sure that you use a hardwired computer when you re-flash. After re-flash, reset the router for 10 seconds by using a paperclip.
Once done, reconfigure the router then try ReadyCloud again.
