Anonymous
Nov 03, 2015R8000 FW 1.0.3.4
http://www.downloads.netgear.com/files/GDC/R8000/R8000-V1.0.3.4_1.1.2.zip
- Aug 10, 2016
It looks like Netgear have in fact abondoned the R8000, while they still seem to support the R7000! Disgusted, I guess the next move is Asus.
The IP6 issue is a joke!
ElaineM
Jan 06, 2016NETGEAR Employee Retired
Jvaillancourt Do you still unable to see the ReadyCloud option?
scrufy, Roy2001 Did you guys try the hard reset after firmware upgrade?
Check if you have "Enabled 20/40 MHz Coexistence" selected.
scrufy
Jan 06, 2016Tutor
I gave up and just plugged the drive into my Kodi server running on an old Linux laptop.
The readyshare has issues. Now the drive streams hd 1080p movie files just fine in mkv or mp4 using usb 2 on Kodi and dlna and that laptop is at least 5 years old. usb 3 on ready share just stutters and is basically unusable for dlna. Once I disabled ready share I have the 2.4 channel usable again. So.. I'd surmise that it is a bug. Doesnt look like it has much attention so could be awhile if it gets addresed.
- scrufyJan 06, 2016Tutor
oh and forgot to mention yes coexist is /was selected. Also downgraded and then re upgraded fw just in case I had a corrupt install.
