horacemiles
Apr 19, 2022Tutor
R8000 HARDWIRE CONNECTIONS HAVE INTERNET BUT WIFI CONNECTIONS DO NOT
Hardware version R8000 FIRMWARE VERSION : V1.0.4.84_10.1.84 After upgrading to this firmware version, I restored the old configuration because I lost all the advance configurations. All hardwared...
- Apr 19, 2022
Glad the reset worked. If see DNS errors or issues, enable IPv6 and set to auto. Should help resolve that.
Enjoy. 📡
Apr 19, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. try factory resetting and don't install using a backup configuration. If something is corrupt in the backup, that could be causing the issue.
