horacemiles
Apr 19, 2022Tutor
R8000 HARDWIRE CONNECTIONS HAVE INTERNET BUT WIFI CONNECTIONS DO NOT
Hardware version R8000 FIRMWARE VERSION : V1.0.4.84_10.1.84 After upgrading to this firmware version, I restored the old configuration because I lost all the advance configurations. All hardwared...
- Apr 19, 2022
Glad the reset worked. If see DNS errors or issues, enable IPv6 and set to auto. Should help resolve that.
Enjoy. 📡
horacemiles
Apr 19, 2022Tutor
It is connected to a cable modem ISP provided. All hardwired connections can access the internet. Only Wifi connections are unable to access the internet. This router is used for a buisness with many configurations. Are you saying that everytime this router updates, I will have reenter all of this configuration information?
Apr 19, 2022Guru - Experienced User
horacemiles wrote:
It is connected to a cable modem ISP provided----doesn't tell me much. what model modem is it? . All hardwired connections can access the internet. Only Wifi connections are unable to access the internet.---I got that from your prior post. This router is used for a buisness with many configurations. Are you saying that everytime this router updates, I will have reenter all of this configuration information?----I didn't say that. But when you're having issues after an update, a factory reset and new install is one of the first things I'd recommend. You usually don't need to do a thing after a firmware upgrade. But if something was corrupt in a setting or something changed enough, thats where we start.
- horacemilesApr 19, 2022Tutor
Ok, I understand that this is community help. But clearly there is a deeper issue here. After the last two firmware updates, the complete configuration is wiped by the update. Is there away to notify netgear of this issue, if the product is outside the warranty?
- plemansApr 19, 2022Guru - Experienced User
the last 2 versions did have issues. its why they keep updating the firmware. And they do watch the forums for repeat issues to pop up.
Did you try the factory reset and clean install?
I will do the factory reset after I capture all the settings as I will need to manually reinput them. I will update after I do all of that.
