Digs
May 09, 2019Aspirant
R8000 has dramatically slower WiFi speeds than wired connection
Hi fourms! I wanted to about others expereinces with wifi speeds on 5GHz Wifi frequency with the R8000. I have a brand-new R8000 running firmware V1.0.4.28_10.1.54 and gigabit fibre to the home...
- May 11, 2019
So it looks like the firmware or router may have been the issue.
I returned the router and exchanged it for the same model. The firmware in the model I got is lower at version V1.0.4.12_10.1.46 rather than the later version I'd updated onto the other router I had.
I ran a few speed tests on this new R8000 - and the speed over wifi nearly matches that of the wired Ethernet now.
I'm happy! sometimes it is simply the hardware (or firmware... I can't say which - so I'll make sure not to update the firmware.)
Digs
May 11, 2019Aspirant
Thanks so much for the thoughts on this!
I've not done a scan of the frequencies nearby - but I'm one of only three visable networks in a new apaprtment building. How do I do a wireless scan? I can use my computer to go through the three networks near me, and using the option key it shows the frequency and channel. The other two are 2.4GHz both on channel 1.
The materals used in the apartment are wallboard and some metal beams? It's brand new - so I can't see it being anything like lath & plaster or things wifi has a hard time going through. The walls in the apaprtment don't have concrete in them from what I can tell. There may be foil insulation somewhere - but I'm quite unsure.
The strength of the Wifi signals I'm getting show the signal is not really being blocked given the RSSI reading is anywhere from -35dBm to -45dBm.
In terms of the NAS device - it is wired in to one of the R8000's ethernet ports.
At this point I can accept the speeds I'm getting over Wifi through speed tests. I think I wasn't anticipating what I precieved to be a huge drop in speeds over Wifi.
I am however dissapointed in the speeds I'm getting connecting to my Qnap NAS over wifi. The NAS is a Qnap TS-431P and the Ethernet port it uses is a Annapurna Gigabit Ethernet adapter. I do understand that reading/writing large amounts of data over wifi is not optimal - but the speeds I'm getting are slower than some basic internet packages.
I feel the bottle-neck in speeds reading and writing to my NAS is the router. I used the BlackMagic Disk Speed test to find out sustained read/write to my network drives over ethernet and over wifi.
The test showed over Wifi the read/write speeds to my NAS were sustained 1-2.5MB/s. Whereas over ethernet I am getting sustained speeds of 95-110MB/s.
To isolate the problem further I connected a standard USB stick to the ReadyShare port on the R8000. Over wifi I get sustained read/writes of 25MB/s +. Over Ethernet it goes up to 70MB/s. This is reasonable and expected.
The NAS is different. Wired of 100MB/s and wireless of 2MB/s? It seems like an excessive drop.
May 11, 2019Guru - Experienced User
Quick question. What wireless did you add to the qnap?
- DigsMay 11, 2019Aspirant
I didn't add a wireless card to the NAS. It's wired in via Ethernet to the R8000. That's it's only connection.
I'm happy! sometimes it is simply the hardware (or firmware... I can't say which - so I'll make sure not to update the firmware.)- IrvSpMay 12, 2019Master
Digs, not updating the firmware can be foolish. Security fixes are in later versions.
The .18 version:
New Features and Enhancements
- Supports collection of router analytics data.
- Added support for SHA256 certificates in lieu of MD5 for OpenVPN.
- Supports the Auto firmware update feature.
Bug Fixes:
- Fixes security issues.
The .28 version:
- Supports tri-band smart connect.
- Allows customers to set timezone to fix Auto-firmware update timing per local timezone.
- Improved Nighthawk Remote management functionality.
- Fixed Internet performance when VLAN is turned ON and under a PPPoE connection.
Bug Fixes:
- Fixes security vulnerability issues
What I'd do? I'd save the configuration you have and install the .28 (which has all prior fixes). My R8000 is running that and works fine. Test and see. If you still have problems, go back to the .12 release and install the settings again via the backup.
Still have a problem, time to contact NG Support via the Support page and MY SUPPORT.
