Concerned-user
Sep 06, 2022Guide
R8000 HAS Internet and does NOT have Internet at the same time
Any thoughts why this may happen with X6 AC3200 WiFi Router (R8000) On one hand, almost all connected Wi-Fi devices drop Wi-Fi or claim "no Internet"; Anveo monitoring service says "SIP offline". ...
Kitsap
Sep 06, 2022Master
Concerned-user wrote:FURRYe38 , setting the R8000 to AP mode is not an option for me, because I use Circle on Netgear.
Kitsap , I don't think I might be affected by the double NAT issue. The BGW320-500 modem/router is properly put into the IP Passthrough mode as described here or here. R8000 is the only router on my network.
For testing purposes only, recommend you configure your R8000 in AP mode to see if your problem goes away. Such a test would also confirm your BGW320-500 modem configuration.
Concerned-user
Sep 07, 2022Guide
Kitsap , FURRYe38 : I note that you both recommend for testing purposes disabling Arris BGW320-500's IP Passthrough mode (https://forums.att.com/conversations/att-internet-equipment/bridgemode-vs-ip-passthrough-info-from-the-att-community/5defbfffbad5f2f606ad5ed2) and changing NETGEAR router to AP mode (https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode).
The article https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode says that in the access point (AP) mode, many NETGEAR features are disabled, including the following features on which I rely:
- Circle Parental Controls
- Guest network
So let' say for the sake of argument that temporarily changing the R8000 into AP mode results in my problem going away. What would be the next step? I cannot stay in the AP mode without those NETGEAR features, especially Circle.
- KitsapSep 07, 2022Master
Concerned-user wrote:Kitsap , FURRYe38 : I note that you both recommend for testing purposes disabling Arris BGW320-500's IP Passthrough mode (https://forums.att.com/conversations/att-internet-equipment/bridgemode-vs-ip-passthrough-info-from-the-att-community/5defbfffbad5f2f606ad5ed2) and changing NETGEAR router to AP mode (https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode).
- Guest network
No, I do not recommend you change the configuration of your BGW320-500. Leave it alone, I do not believe that configuration is effectively disabling the router function. Configure the R8000 in AP mode and restart your network. This disables the router function in the R8000 as well as other features. If devices that connect to your R8000 Wi-Fi or via Ethernet have full and functional access to the internet, than the BGW320-500 is still functioning as a router. At the same time, check to see if other devices connected to the R8000 are losing internet access (your original problem).
- Concerned-userSep 07, 2022Guide
Kitsap : in this old thread FURRYe38 wrote "When [Orbi router behind the ATT gateway is] in AP mode, the ATT [gateway Arris BGW210-700] pass through needs to be disabled. Pass through is for only when the Orbi [router behind the ATT gateway] is in router mode."
- FURRYe38Sep 07, 2022Guru - Experienced User
Have you tried the Router in AP mode yet behind the ATT modem with Pass thru disabled on the modem?
