Jo_Neri's avatar
Jo_Neri
R8000 has two Mac IDs
I recently acquired a Nighthawk X6 R8000 router and connected to my fibre to home conection.
I noticed something peculiar.
The Mac ID of my Router is indicated as 2c:30:33:d2:8c:f1. Ever since I installed this router I noticed an increased data usage.
When I check the usage log on fibre ISP I noticed that the Mac ID of the connection was reflected as 2c:30:33:d2:8c:f2.
When I checked the router setup I observed that 2c:30:33:d2:8c:f2 is shown as the Mac ID of the internet port, ?? 2c:30:33:d2:8c:f1 is the Mac Id of teh router.
I am a rookie and a bit confused. How are there two Mac Ids for this router ?
Looking forward to an explanation.
Regds
Jo Neri
  • MAC addresses are tied to interfaces.  Therefore, it's normal for a router to have multiple MAC addresses.
  • StephenB's avatar
    Is this on a label on the router?  Or are you seeing this mac address on a screen somewhere?
    • Jo_Neri's avatar
      Jo_Neri
      Hello Stephen
      The 2c:30:33:d2:8c:f1. Mac Id is on the label of the router. It also shows under the Router information in "Advanced"
      The 2c:30:33:d2:8c:f2 Mac Id is reflected in the "Internet Port" in 'Advanced'  and also reflects as the log in Mac Id on my ISP logs.
      Regds
      Jo
      • TheEther's avatar
        TheEther
        Guru
