Tribefan
Nov 03, 2021Initiate
R8000 HOW DO I ROLLBACK THE FIRMWARE VERSION??
Hello... After downloading the current firmware version (1.0.4.76) I keep getting the SITE CANNOT BE REACHED error, although it will take me to the site eventually after 15-30 seconds or so (this...
Nov 04, 2021Guru - Experienced User
go to the support site.
https://www.netgear.com/support/product/r8000
Click on downloads.
Then click on "+view previous versions"
that'll have the older versions.
simply download it, extract it, then follow the manual firmware update process.
One thing to try prior to downgrading is enable IPv6. See if that helps .
