Retired_Member
Mar 23, 2019R8000 I want to define my Internet Bandwidth
Hello,
how to change the setting Let Speedtest detect my Internet bandwidth into I want to define my Internet Bandwidth?
I select the second option, input the upload and download Mbps speeds ...
- Retired_MemberMar 24, 2019
Its not the browser, I tried Safari macOS and iOS, IE11 and Chrome on Win10.
I will close this as nowbody knows the solution, other cannot read and are just curious and from Netgear I dont expect nothing.
Retired_Member
Mar 24, 2019"Well, that's not what you asked initially, isn't it?"
Yes, innitially I asked I want to define my Internet Bandwidth, the alternative formulation would be Switch off Speedtest, becouse you can have only one of two mentioned options.
schumaku
Mar 24, 2019Guru - Experienced User
Many other open questions.
Might be potentially a browser issue - not aware the simple Nighthawk router Web UI does bring lots of challenges, worth trying an alternate browser, drop the browser cache, think about Internet security packages probably interfering with the Web traffic which might interfere the UI JavaScript somehow.
- michaelkenwardMar 24, 2019Guru - Experienced User
I am still not convinced that we have got the the bottom of the "why" question.
The page that seems to fixate Retired_Member is all about settings for QoS.
But another message from Retired_Member says that they have turned off QoS.
That page, the one with the Speedtest link, is redundant if you are not using QoS.
So, back to the first question, forget about the QoS page, what does Retired_Member really want to achieve?
- schumakuMar 24, 2019Guru - Experienced User
michaelkenward read the OPs original post again
Retired_Member wrote:
I select the second option, input the upload and download Mbps speeds and click on Apply. A save bar is showing progress, when the screen reloads the option Let Speedtest detect my Internet bandwidth is still active.
The way I read this I understand that the manual settings are not applied, the router does fall-back to the speed test.
That first message just describes a symptom. We still do not know what Retired_Member wants to achieve, only that something goes wrong.
Is the idea to tweak QoS? Something else?
I try not to interpret what people say. I am more interested in getting down to the basics.
Tell us what the underlying problem is, not where you think things are going wrong, and then someone might be able to home in on solutions.
Nothing to tweak on QoS - simply apply user defined up- and downlink speeds to the QoS settings.
Dear Michael,
please reread my initial posting. Word by Word!
Why is not important.
Retired_Member have a complete different Web browser - like one one a mobile phone or tablet - available to test and compare?
Well possible a bug, as you initially suspected - strange no other reports in the community. Christian_R food for Netgear's PQA and the bug army.
A possible solution would be using the current or some older firmware ... but you keep many more required information a secret, so blame yourself, too. That's not the way communtiy help should work.
PS. Have seen another community member showing the same QoS form (on a R7000) - without the two input fields .... Netgear consumer formware departement isn't at it's best performance for a while.
- shadowsportsMar 24, 2019Hero
Retired_Member
The QoS feature has two settings. On or off. The subsettings only become "active" if the feature is enabled. If its not turned on, then the (radio) button options below do not do anything or apply.
"Let SpeedTest Detect"...
or
"I want to define"...
Please stop looking for or trying to define an option in a feature which is not enabled.
I'm basing that from this comment:
"Schumaku,
I have the QoS switched off and I want, for various reasons, to get rid of Ookla from my router."
QoS is nothing but trouble. Poorly implemented and disfunctional.
shadowsports all due respect - please exaclty red the OPs inital post. He _did_ try to tick the manual definition, entered bandwidth numbers, and did find ... after some time to apply ... that the setting isn't in place, it fail-back the speed test ticked instead.
schumaku ... Thanks. I saw it and you're right.
It's just not worth the time. If its a bug, netgear isn't going to fix it. Not in our lifetime anyway.
@Valdo, you are now armed with our recommendations. Mine, don't use QoS.
schumaku anf michaelkenward 's try using a differnt browser, resetting and reconfiguring or using a different FW.
I've done extensive testing with QoS.. once enabled or if a speed test is performed, the settings "stick" even if you disable them later. You actually have to reflash to get the original database and/or no speedtest results. Nothing but a headache. Buggy for sure.
shadowsports wrote:
schumaku anf michaelkenward 's try using a differnt browser, ...
We can mark this - already done (three different OS, various browsers, ...) - always assuming there is no Internet Security system deployed to ll these systems, or there is no in-line device (like a proxy, security appliance, ..) potentially interfering.
Especially as we have no idea why Retired_Member wants to use QoS.
Simply repeating the same thing over and over again adds nothing to the explanation.
QoS looks like a dying technology, swept away by rising Internet speeds. At one stage the recommendation, from Netgear and others, was that for people on Gb Internet QoS not only achieves nothing it slows down things as the router performs its magic.
Since then I have see suggestions that QoS is of little value over 300 Mbps.
So, as always, I go back to basics. Is this someone fiddling with QoS "because it is there" or someone who sees congestion or issues with playing games on line?
If the latter, it is possible that something else is getting in the way, and that QoS will achieve nothing.
Serious gamers can always opt for something like the XR500 or another box in the gaming router series that supports DumaOS. These deploy techniques that are way beyond anything that you will get with simple QoS.
I have just noticed that we don't actually know which firmware Retired_Member has on the R8000. AS far as I can see, we never did get an answer when schumaku posed that question. Kind of basic information when someone wants to know about possible firmware bugs. Maybe newer firmware fixed it, or it isn't there in an older version. Who knows?
