Retired_Member
Mar 23, 2019R8000 I want to define my Internet Bandwidth
Hello,
how to change the setting Let Speedtest detect my Internet bandwidth into I want to define my Internet Bandwidth?
I select the second option, input the upload and download Mbps speeds ...
- Retired_MemberMar 24, 2019
Its not the browser, I tried Safari macOS and iOS, IE11 and Chrome on Win10.
I will close this as nowbody knows the solution, other cannot read and are just curious and from Netgear I dont expect nothing.
schumaku
Mar 24, 2019Guru - Experienced User
michaelkenward read the OPs original post again
Retired_Member wrote:
I select the second option, input the upload and download Mbps speeds and click on Apply. A save bar is showing progress, when the screen reloads the option Let Speedtest detect my Internet bandwidth is still active.
The way I read this I understand that the manual settings are not applied, the router does fall-back to the speed test.
michaelkenward
That first message just describes a symptom. We still do not know what Retired_Member wants to achieve, only that something goes wrong.
Is the idea to tweak QoS? Something else?
I try not to interpret what people say. I am more interested in getting down to the basics.
Tell us what the underlying problem is, not where you think things are going wrong, and then someone might be able to home in on solutions.
- schumakuMar 24, 2019Guru - Experienced User
Nothing to tweak on QoS - simply apply user defined up- and downlink speeds to the QoS settings.
