Retired_Member
Mar 23, 2019R8000 I want to define my Internet Bandwidth
Hello,
how to change the setting Let Speedtest detect my Internet bandwidth into I want to define my Internet Bandwidth?
I select the second option, input the upload and download Mbps speeds ...
- Retired_MemberMar 24, 2019
Its not the browser, I tried Safari macOS and iOS, IE11 and Chrome on Win10.
I will close this as nowbody knows the solution, other cannot read and are just curious and from Netgear I dont expect nothing.
shadowsports
Mar 24, 2019Hero
schumaku ... Thanks. I saw it and you're right.
It's just not worth the time. If its a bug, netgear isn't going to fix it. Not in our lifetime anyway.
@Valdo, you are now armed with our recommendations. Mine, don't use QoS.
schumaku anf michaelkenward 's try using a differnt browser, resetting and reconfiguring or using a different FW.
I've done extensive testing with QoS.. once enabled or if a speed test is performed, the settings "stick" even if you disable them later. You actually have to reflash to get the original database and/or no speedtest results. Nothing but a headache. Buggy for sure.
michaelkenward
Mar 24, 2019Guru - Experienced User
Especially as we have no idea why Retired_Member wants to use QoS.
Simply repeating the same thing over and over again adds nothing to the explanation.
QoS looks like a dying technology, swept away by rising Internet speeds. At one stage the recommendation, from Netgear and others, was that for people on Gb Internet QoS not only achieves nothing it slows down things as the router performs its magic.
Since then I have see suggestions that QoS is of little value over 300 Mbps.
So, as always, I go back to basics. Is this someone fiddling with QoS "because it is there" or someone who sees congestion or issues with playing games on line?
If the latter, it is possible that something else is getting in the way, and that QoS will achieve nothing.
Serious gamers can always opt for something like the XR500 or another box in the gaming router series that supports DumaOS. These deploy techniques that are way beyond anything that you will get with simple QoS.
I have just noticed that we don't actually know which firmware Retired_Member has on the R8000. AS far as I can see, we never did get an answer when schumaku posed that question. Kind of basic information when someone wants to know about possible firmware bugs. Maybe newer firmware fixed it, or it isn't there in an older version. Who knows?
