SidJacks
Nov 27, 2022Aspirant
R8000 Internet port not working
Hello all. I am trying to get my R8000 to successfully connect, but nothing is lighting up the Internet Port. I have tested with other cables on a different router and the cables are good. A loopb...
Nov 28, 2022Guru - Experienced User
So disconnect everything from the router.
Press the reset button for 10 seconds then release. Unplug the power adapter from the wall out let for 30 seconds, then back in.
Have one wired PC connected to the router.
Walk thru the setup wizard, you can manually setup the router and get to the home screen. Use MS Edge for this.
What FW is loaded on the router?
SidJacks
Nov 29, 2022Aspirant
Just wanted to follow up.
I haven't been able to plug directly to a computer yet to test.
But the firmware was updated to the latest version on Sunday night. I downloaded directly from netgears site and updated over wifi.
- FURRYe38Nov 30, 2022Guru - Experienced User
It's not recommended to update router FW over wifi. Use ethernet connected PC for this.
- SidJacksNov 30, 2022AspirantGood to know! I will try it and let you know what happens.
- FURRYe38Dec 01, 2022Guru - Experienced User
đ
