tylernealis86
Jun 11, 2017Aspirant
R8000 issues after resetting to factory defaults
I pushed the reset button on the back of the router and now I cannot "configure the internet connection". I can't get into the user interface. Every time I open internet explorer it takes me to router...
- Jun 12, 2017
All thanks for the input but it started working after the fourth reset.
The only thing different this time was I disconnected the power to my firestick so that nothing was trying to access the wifi while it was coming online..
Not sure why the reset worked after I unplugged the firestick but thats all I did??
Again thanks for the input and the willingness to help me out. I appreciate the forum... much more than netgear since you have to pay to talk to tech support, but whatever....
William10a
Jun 12, 2017Master
I hope that they get the router set up and their internet back.
michaelkenward
Jun 12, 2017Guru - Experienced User
tylernealis86 seems to have disappeared. First the question, then the follow up with more information. After that, nothing. Perhaps they fixed it and haven't bothered to tell us.
