treehugger767's avatar
Oct 06, 2017
r8000 led 2 stays red
After updating to firmware version V1.0.3.54_1.1.37 the number 2 led stays red. Router seems to be functioning normally as far as I can tell. Tried a power off and back on but the does not turn white...
  • William10a's avatar
    Oct 07, 2017
    treehugger767 wrote:
    After updating to firmware version V1.0.3.54_1.1.37 the number 2 led stays red. Router seems to be functioning normally as far as I can tell. Tried a power off and back on but the does not turn white. I have checked the manual but it does not mention that led in the trouble shooting section.
    Did do a reset on the router gusting you are talking the lan port number 2 on the router, if a device is connect it amber is 10/100mb and white is 1gb.
