THX-1138
Oct 22, 2022Aspirant
R8000 limit on DHCP clients?
I haven't been able to find this issue anywhere, so a new post. I'm running an R8000 with the lastest (as of 2022-10-21) firmware. My 2.4GHz and 5GHz networks have different SSIDs. The R8000 provid...
Oct 22, 2022Guru - Experienced User
How many clients are you trying to connect to the router?
I had about 30-35 connected to my R7960P which uses same base code as the R8000P
Are you using IP address reservations for your devices or just letting the router give out IP addresses?
Are you using default IP address range?
- THX-1138Dec 10, 2022AspirantI've never seen more than 30 attached devices. Some have reserved IP addresses, others do not. I am not using the default address range. The logs show no record of receiving either an association or a lease request from the attempting MAC address.
