suekimtoo
Jul 16, 2016Aspirant
R8000 losing speed
Losing speed between modem and router. Had TWC "extreme" internet which is 30mbps and router was delivering 22mbps both ethernet and wireless while ethernet direct from modem showed over 40mbps. Upgr...
- Retired_MemberJul 18, 2016
In post 3 I gave you a suggestion to follow, You have to solve the wired problem first. Reset to defaults, and test, same problem contact support.
The reset to defaults is done by pressing reset util power led flashes, see manual if still unsure of that process.
suekimtoo
Jul 18, 2016Aspirant
All the changes were made and then tested using wireless. I only used the wired connection to the modem to establish that my TWC service was indeed sending me 50mbps which I was paying for. And I tried wired through the router to see if there was any difference between the wired vs wireless the Nighthawk was putting out.
Retired_Member
Jul 18, 2016In post 3 I gave you a suggestion to follow, You have to solve the wired problem first. Reset to defaults, and test, same problem contact support.
