B_Greene
Jan 12, 2017Aspirant
R8000 Losses Connection
Most every day when I go to use my desktop with windows 10, I have loss connection to my router. My router is an X6 R8000 and I have loaded the latest firmware through the Net Genie. If I disconnect ...
- Jan 23, 2017
Hi iamjosh,
Reset the router to factory default and manually reconfigure.
B_Greene
Jan 16, 2017Aspirant
1. Is your desktop wired to the router or wireless connected? It is wireless. When this happened yesterday, my desktop was disconnected, but my son was currently using his laptop online. So the modem was functioning at the time.
2. Did it happen after the update or same problem prior to the update? I didnt update router. The new unit had the latest router when I checked.
3. Perform a factory reset and reconfigure it manually. .......Is there specific settings that re suspect? If I was to start from scratch, not sure of required settings.
iamjosh
Jan 23, 2017Aspirant
After latest firmware many of my devices drop conections to the wifi, the amazon echo has been singing a lovely tune at all hours to let us know how bad the wifi is after the latest firmware (V1.0.3.32_1.1.21) Video Buffers and lags on all of my devices as well. Have you found any solutions?. So far an hour on hold /working with support and I've gotten zilch...
