B_Greene
Jan 12, 2017Aspirant
R8000 Losses Connection
Most every day when I go to use my desktop with windows 10, I have loss connection to my router. My router is an X6 R8000 and I have loaded the latest firmware through the Net Genie. If I disconnect ...
- Jan 23, 2017
Hi iamjosh,
Reset the router to factory default and manually reconfigure.
LeeH
Feb 02, 2017Prodigy
I have 17 devices running off my router. I was having problems with devices loosing network connections. I opened the routers web interface and went to the Advanced Tab and selected Setup and LAN Setup under that. I then used the +Add button at the bottom of the page to reserve all my IP addresses one by one and clicked the apply button at the top of the page after reserving all the addresses. I also turned on all my networked devices prior to reserving the IP addresses. Cell phones were particularly bad at getting new IP's that conflicted with other devices. This worked for me.
