B_Greene
Jan 12, 2017Aspirant
R8000 Losses Connection
Most every day when I go to use my desktop with windows 10, I have loss connection to my router. My router is an X6 R8000 and I have loaded the latest firmware through the Net Genie. If I disconnect ...
- Jan 23, 2017
Hi iamjosh,
Reset the router to factory default and manually reconfigure.
crystalgipsy
Feb 25, 2017Aspirant
I am having the exact same issues with my R8000 since the latest firmware updates it was running fine until these. I have what appears to be random reboots as DHCP seems to reassign IP addresses randomly. Devices that where connnected get disconnected and at times very poor bandwidth. I have done a factory reset and the fun still remains. I am resulting to give all the devices connected a DHCP reservation to see if that helps.
JamesGL
Mar 01, 2017NETGEAR Employee Retired
Hi All,
Try this firmware and reset. Check and observe.
http://kb.netgear.com/000037342/R8000-Firmware-Version-1-0-3-36?cid=wmt_netgear_organic
- crystalgipsyMar 02, 2017Aspirant
When you say reset, do you mean perform a factory reset or simpy a reboot of the router?
- JamesGLMar 02, 2017NETGEAR Employee Retired
Hi crystalgipsy,
Perform a factory reset.
